I found an interesting scenario on DoW and I decided to post it here:
Thankyou for sharing this. I like a larger map with plenty of terrain.
I have posted a short video here: M44Print - new features v7.8 which shows some of the new features in the forthcoming v7.8. If you are interested, starting at 5:24 it also shows how to use the ‘Exclusions’ feature, which has appeared in all versions so far, to reposition text, since the suitability of its placement can vary wildly from map to map. It is probably the only thing I change every time I make one.
But those things that you can make with labels for example IC do not work. Why.
The extra elements will be in the new version.(7.8)
