Wire clarification please
after battling in wire at minus one, on the next turn can i simply move out of the hex without removing the wire?
Hi Mike,
You can move out of the wire on the following turn. The restrictions on movement are only when entering the hex. It is just slowing you down and is not impassable.
thanks so much…cheers…
Thanks..
I have another question if you don’t mind…
When playing a Barrage card ( select 1 enemy unit, 4 attack dice, ignoring any terrain protections)
If the opposing player in in a field bunker, do i use only 3 dice because of bunker restrictions, or is the field bunker not included in terrain protections? basically is it 4 dice or 3? thanks again..
It’s 4 dice I am sure
