M44 Badges for home printing
If you are tired of looking for the right badge for your game because they are different on both sides, well, I have made a pdf with all known badges and the correct quantity from roll calls in all expansions (there might be a few types of badges with 1 extra, just so it fits for the double sided printing).
It is a 6 page pdf, with 3 pages duplicated so it will print the same pages on both sides, if you print duplex. This way, the badge token will be the same. No more shuffling and looking at the other sides.
Best to either print on 300+gsm card stock if your printer can do so, or adhesive printer paper to stick to thick grey board and cut out, make sure you stick the duplicate sheet to the other. If printing on adhesive paper, print the pages separate, not duplex… I added a green back ground so if you rather cut into squares, you wont get a bright white sections on the badges
https://drive.google.com/file/d/1CVxx-s7OHedOttCb-MeId7XHilHXe-NG/view?usp=sharing
full drive contents in this link
I don’t have access.
try again for me if you dont mind :slight_smile:
Wow that is amazing!!! Do you take the badges from m44 editor? I made my own set of badges 2 weeks ago and I took all the m44 badges from editor.
No they are from scans of game components. 300dpi actual size scans. The only ones that I had to edit are Hobarts funnies, (found a decent replacement icon) French nation, (which isn’t used) Patrol car, command car and nebelwerfer. All those were not actually printed in any expansions apparently, mainly because they were for the D-Day maps.
But you can find hobart’s funnies, screeming meemies and france army badges on editor.
True but they are low resolution. I prefer better quality, thats why I did my own to keep in line with the other scans I used.
Nice, but why a green background?
So it blends in with board better if people want to cut them square. Cutting the shape itsrlf is tedious lol
It does explain in the original post
These badges are smaller than the standard badges! Why? I printed them all and after I made them I saw that they are smaller.
Did you turn off scaling in your printer options? They print 100% correct size if you turn it off
Yes, I printed them at 100% scale.
No idea then. I printed them off an they are same size as genuine ones.
OK. I will play with them at that size. They are very good regardless their size.
